hello I bought a nokia 6260 and I really need some help configuring the MMS Settings so I will be able to use it. I am with FIDO here in canada. I have all the configuration on my phone but its not working on my phone. Pls help, I appreciate ur help in advance. Thank you
6260 MMS Settings
What, exactly, do you mean with "all the configuration"?
Go to the "Settings" app, select "Connection" and then "Access Points" and then what you think is the MMS access point there and then post the details of fields you see there ("Connection name", "Data bearer", "Access point name", etc.).
If you do that, someone that has working FIDO MMS settings should be able to say if they are right or wrong.
Then go to the "Messaging" app, hit "Options", select "Settings" and in "Multimedia message" make sure that the "Access point in use" is the correct one.
If that's not enough, check with FIDO customer service (call them) that your subscription/account allows for sending of MMS.
