help!my screen doesnt work!
4 replies · 2,585 views · Started 16 June 2005
help my screen doesnt work any more it doesnt respond to touch at all only the actuall buttons work i cant dail using the numbers cause it doesnt recognize me touching the screen any more ive done every thing i know cut it off then put it back on ive taken the battery out then put it back in the mmc and the sim card what do i do somebody help me please this is my baby please help me i paid to much for this phone
i have the same problem with my 7710, did you ever resolved yours. please let me know desperate nokia 7710 owner
:redface:
chocalation wrote:help my screen doesnt work any more it doesnt respond to touch at all only the actuall buttons work i cant dail using the numbers cause it doesnt recognize me touching the screen any more ive done every thing i know cut it off then put it back on ive taken the battery out then put it back in the mmc and the sim card what do i do somebody help me please this is my baby please help me i paid to much for this phone
Did you tried screen calibration? I had this problem to in the begin till I tried screen calibration. Try to touch the figures on the best place. Good luck, I hope it will work.
Allard
Thanks, yes i tried screen calibration but no luck, the response of the touch screen is intermittent, ie some times the screen freezes, but i can still use the buttons okay. i may have to send it off to Nokia for repairs. 😉
threets wrote:Thanks, yes i tried screen calibration but no luck, the response of the touch screen is intermittent, ie some times the screen freezes, but i can still use the buttons okay. i may have to send it off to Nokia for repairs. 😉
Okay, I hope it can be fixed. I think also that it's the best way to go to Nokia Support. They have to help you, good luck!
Allard
