cracked cover....replacement?
13 replies · 2,594 views · Started 16 June 2005
The clip on my new krussel case has cracked the cover of my phone over the screen, its not a big crack at the moment but I can see it getting worse in the future.
Is there anywhere where I can get a replacement front cover?
Vindi
They arent available as an accessory. You will have to send it to a service repair centre for an Out Of Warranty cosmetic damage repair. Call the service centre for a quote.
The phone is less than a month old, but I take it that cosmetic damage isnt covered by the warranty.
I wonder if they would mail me a replacement cover to save me loosing my phone for a month :/
It's highly unlikely it's covered by warranty, but Sendo will repair it as an out of warranty repair. (don't know what the cost would be though)
Then I'm interested too. I asked if they could get me a new cover because of a lot of scratches on the screen, but I simply didn't got an answer...
�58.75 would be the default cost for any out of warenty repair on a Sendo X in the UK. 😞
Thats the reason why im looking for a replacement cover.
maybe i should try my hand at plastic moulding lol
Mordred 660 wrote:@trim - try some good plastic polish to rid yourself of the scratches
Thanks, I'll give it a try.
stuclark wrote:Is it me or is there an echo in here?
WTF is going on? Some of you guys are on a holiday trip to the Alps, or what? 😃 Too much echos here ...
If you use a display polish be aware, that you have to use much pressure to get rid of the - what i call - screen surface protection. It is in fact causing this "rainbow effect" on the screen in sunlight. You can easily (in some hours) polish it away. BUT after that, your screen is much more "softer" and will become scratched more easily.
