bluetooth probs
2 replies · 1,584 views · Started 16 June 2005
i am having problems trying to connect to my pc using bluetooth.
I have a nokia 6600, and can connect from my pc to the phone and send files from my pc to my phone using bluetooth, but cant send a file from my phone to my computer using bluetooth. i have checked my dongle on another bluetooth device and had no problems sending or recieveing
has anyone experienced similar problems?
I had similar problems....
Right click on the Bluetooth icon (bottom right hand of your computer screen) and click on 'receive files'. You can now send the file via your phone.
The problem is this is a bit of a ball ache as you have to click on receive file every time you want to send a file from your phone to your computer.
Hope this helps.
i have found that if i dont have my blue soleil display up and the little bluetooth sign in my tray then i can send files from my fone to my pc, but if i have my display up on screen it wont connect....
wierd aint it
