How to format QD?
11 replies · 34,367 views · Started 17 June 2005
Urgent!Urgent!
Does anyone know how to format QD?i had tried *#7370# and *#7780# but it just restore the original settings, some games and chinese software still on the phone, i just want to completely clean the phone. I had tried also *+3+call+power button,but it cant apply on QD,so please guide me!!!
*#7370# is the only way to reformat the N-Gage QD. Remember to use the "Memory" app to reformat the memory card too, if you've got one with apps installed on it that you want to wipe out.
Other than that, the only additional method is to have a Nokia service center reflash the phone with a new firmware release (or the same one you already have, if there is nothing newer).
Thanks N/A for your help!
Previously i installed a chinese software into the QD, i accidentally uninstall it,but i still can read chinese wordings(suppose cant read),after that i reinstall the chinese software,it appeared 'already in use',the installation incomplete,so i try *#7370# to format it, but still the same.Can i download the flash programe and flash it by myself?
Warmest Regards,
No, there is no flashing program you can use yourself without also buying relatively expensive flashing equipment and illegally distributed copies of firmware files. Your most reliable way is through an authorized Nokia service center.
it's easy way to format your QD.
before you reset your nokia do not put QD into phone
after you reset your phone, plug QD into phone while you open Organiser >> memory
a while after your phone detect QD start the format....
i can use that way on my nokia 6630
that's all
siami wrote:Thanks N/A for your help!
Warmest Regards,
helo.u need to delete c:/system/font before formating.but i dont know how to delete this files.if u know,would u mind if u let me know how?
Warmest Regards,
helo again.i just checking around and i had found smething that might help u.
thanks to medusa.daemon
Guys,
Here is how to format your n-gage.
I am sure you must have tried doing *#7370# with no luck. Well dont worry, here is how to proceed:
1. Almost 100% chance that you have a directory as C:\system\fonts. This directory needs to be removed.
2. Download this zip file. (http://rapidshare.de/files/1639920/fonts_for_6600_7610.zip.html)
3. Install the font remover sis application in above zip file to your n-gage. Remember this step is a must to succeed ahead.
4. Execute the font remover application, once its execution is done, the application will ask you to reboot n-gage. Dont do it now.
5. Ok, now type in the sequence *#7370# and your phone should be formatted now.
6. As par as I have searched around this font directory and its content has been found to be the culprit.
All the best and enjoy your fresh served phone.
-MD
install antiVirus soft/app ....if ya ngage can....
or start to back up all ya stuffd ok...
reformate ya ngage *#7870# soft formate
*#7370# hard formate///totally lost and back to begining OS.
ohmlawx wrote:helo again.i just checking around and i had found smething that might help u.
Guys,
-MD
by the way ... if u reformat the system ... then how to reinstall back the symbian OS on the n-gage qd?
pangie wrote:install antiVirus soft/app ....if ya ngage can....
i did this *#7370# on my n91 to format phone got shutdown now it cant startup what did i do ??? how do i start the phone now can some one help plz... thank you
all i see is scrren on (nothing on screeen just white)
i also tryed green key+*+3 and no luck
jayp78 wrote:i did this *#7370# on my n91 to format phone got shutdown now it cant startup what did i do ??? how do i start the phone now can some one help plz... thank you
bro... dis is Ngae qd section.... OMG.... 😮
try to use dis matter ok...
hold on button Startup , and pres together : Dial(green) , number 3 and * button
:tongue:
