Communicator on LAN
5 replies · 2,320 views · Started 06 November 2002
Now i saw a software named Extended Internet , which lets us connect to internet via another GPRS phone , or modem , i was wondering will it be possible that if we connect it on or via Local Area Network ! i havent tried that yet , but if someone else did or know something about it , plz share it.
Yes, and in time I'll review this app and feature 😉
but to keep it short, you'll need to install a mocha ppp client on your desktop pc and then you cna use Extended internet to connect to your lan through your desktop.
Thanks , Thats really great .... but what that mocha ppp client have to do it with ? wont that be possible without installing any additional software on pc .... like simply install extended internet on my communicator and put the serial cable on serial interface of my pc ... and start! 8)
becoz .. what incase when i use an external modem to connect to internet like Us robotics external.... put the serial cable in it and start ... where would i have to install mocha ppp then ?
:bday:
check the extend internet site for the instructions.
The communicator can't force the computer tog ive you internet access through the serial.
The mocha ppp just needs to be installed on a pc with internet. When you then connect to serial, mochappp will detect this and use the pc's internet to provide you the internet 😉
[quote="Dazler"]check the extend internet site for the instructions.
The mocha ppp just needs to be installed on a pc with internet. When you then connect to serial, mochappp will detect this and use the pc's internet to provide you the internet 😉[/quote]
WHAT`s a mocha?
