Need '3' operator Id for Logo
12 replies · 3,087 views · Started 17 June 2005
Can someone please tell me what '3's network id is. I am trying to change my op logo to a fancy three one. But even though opman says it has changed it doesn't appear. But when i put an o2 sim in, then my fancy '3' logo appears.
thanks
p.s my phone is a N6680
I made a nice little logo and I too can't get it to work.
Tell me, does your o2 sim work in your 6680? and if so, how did you unlock it?
Does anyone have a solution to the operator logo saga by any chance?
Attachments: 234_20_0.bmp
Mr Brainz wrote:I made a nice little logo and I too can't get it to work.
I have a vodafone 6680 and a 3 6680. I have had the vodafone unlocked, and use my 3 sim card. Yesterday I made a call and when I had finished My 3 logo appeared and stayed on the phone for ages. A soon as I lost my signal it disappeared back to the boring no.3 and hasn't been back since !!!!!!!!!!
p.s
Your Logo is the Mutz. I will use that, just in case
use FExplorer and then open up the picture ( logo ) . Finally. choose file and set as operator logo.
My FExplorer must not be a recent enough version to do the operator logo thing.
I've installed the Logo Manger .SIS program to do it. It still don't work.
I noticed when I had my orange 6680 there was an operator logo setting in a menu somewhere. It's not present on my Three 6680. They must have turned the option off. God knows why...
Nice Operator Logo.
Any idea how I can make it blend in with my theme? My themes colour is red. The Op Logo stands out as a white box in theme. How does one make it transparent with only the logo visible?
Doc wrote:Nice Operator Logo.
I have no idea mate. It was something I knocked up in a matter of minutes with MS Paint. I'm not too hot up on this stuff.
WEIRDEST THING just happened to me. I was on the phone using a bluetooth headset to my friend when...
It just appeared out of nowhere. I finished the convosation, then about 30 secs after I pushed the red key again and it disappeared 😞
Something tells me the firmware is still WELL buggy
PS sorry for the grainy image. Was taken on the spur of the moment with my old 7600!
bjarke wrote:Bad news: 3 doesnt support custom oplogos...
In what way doesn't it support it? Does the SIM tell the phone to block it?
I've changed my firmware from the supplied 3 one, to the generic one, and I still can't get a bmp oplogo.
As the handset is locked to 3, I can't put another SIM in to see if it IS the SIM or not. 😡
BadTasteUK wrote:In what way doesn't it support it? Does the SIM tell the phone to block it?
Update.... having just returned from France, I can confirm that the op logos appeared for all 3 networks (I had already stored them before leaving), so it look as though 3 only stop you putting a logo over their network and that of O2 (which also shows up as 3). 😡
