3230 keypad autolock
8 replies · 6,420 views · Started 18 June 2005
hi
i got this new 3230 ..everything's great except that the keypad gets auto locked within 10 secs..if left idle...its getting real frustrating now and there isnt any option in the phone settings to disable this or increase the timing....is there anyway i can disable this option ..or any software ??????HELP
wateva27 wrote:hi
this is strange!
what fw version has the phone? (push *#0000# to find out)
Rich_uk wrote:this is strange!
hey
its V 3.0505.2....
wateva27 wrote:hey
its V 3.0505.2....
Mine is V 3.0512.0 and doesn't have that feature. I had to install a 3rd party software just to have an auto keylock. Try to check if your phone has eprofiles installed in it or maybe jjl auto keylock. If you have just disble the feature or if you don't like it just uninstall it.
I have the same firmware version and mine doesnt have autolock, how can i get this feature as i really miss it from my old nokia....
abbadon2001 wrote:I have the same firmware version and mine doesnt have autolock, how can i get this feature as i really miss it from my old nokia....
here you go
Extended Profiler has a built in auto keylock which i'v found to be the most stable, i tried a few others on my 3650 and all had nightmare troubles of not working right or the phone crashing on me. Ex Profiler is also cool for all the extra features it gives to, each profile can be customised to give options you want when you want and when you dont.
Duke.
