Nokia 6680 Flash Light
4 replies · 8,692 views · Started 18 June 2005
Does anyone know of any software (freeware or not free) which can use the flash on the 6680 as a flash light? if there isnt one, can one of you guys (developers) make one? that would really be handy, better than the flash light programs
themafia.69 wrote:Does anyone know of any software (freeware or not free) which can use the flash on the 6680 as a flash light? if there isnt one, can one of you guys (developers) make one? that would really be handy, better than the flash light programs
I've heard that as long as you have the latest firmware, programs like Photographer can use it. My firmware is v2.04.15. I've tried Photographer by Openbit, but it doesn't work 😡
no no i dont need it for when i take pics, i want it so i can use it as a flash light, because its a very bright light
I wud also like a app like that...
but ive found a temp solution to the probb...
cuz is u start recording with the vid recorder and pause the recording the flash stays on...
but not it is not as brigth as it can be so if anyone know of a app or can develop a app that can use the full potencial of the flash that would be nice 😊
When i first used flexicam with my 6680, it steadily lit up the flash light with small blinks in between.. i was scared i might blow out the flash or something so i got rid of it..
