Nokia 6600 retrieving contacts from sim
2 replies · 5,390 views · Started 19 June 2005
Is there a program out for the Nokia 6600 where I can retrieve my contacts from my sim as they are stored on there.
Andrew
andrewsexton wrote:Is there a program out for the Nokia 6600 where I can retrieve my contacts from my sim as they are stored on there.
Andrew
why don't u try the easiest method..ok..first step,go to contact...then,select options,and scroll down until u found sim directory..select sim directory.u'll be taken to a sim directory menu..now click options,choose copy to contacts...thats it,now u have transferred ur contacts from ur sim....=).hope this helps..
Andrew
Download svCard software (Smart V Card ) version 1.0 from www.symbianware.com and install it on your mobile than just export all contact to your Memory Card you can import all contacts when ever u want...
Sahir Jaan
