I have a big problem......whenever i put smartmovie settings to 512kbs vid and 44100Hz frequency + 128kbs bitrate audio....the sounds becomes a little bit faster than the subtitles...
AND THIS HAPPENS WHEN I OPEN IT IN WINDOWS. JUST IMAGINE IF I WERE TO PUT IT IN THE PHONE 😮 ..
is there anyway to make it smooth.....BTW i want to have good sounds and vid..memory doesnt matter to me as long as its good 😃 ..
Has someone discovered any good settings?????
in smart movie you can alter the delay of the sound + / -
this is under the 'audio preroll time' in options.
if you play it on your phone the default setting should be enough to play the video correctly.
i think by default smart movie does this preroll so that you cant use thier encoder to play the videos on other players, but i may be wrong.
hope this helps
The_Vindicator wrote:in smart movie you can alter the delay of the sound + / -
this is under the 'audio preroll time' in options. if you play it on your phone the default setting should be enough to play the video correctly.
hope this helps
THis doesnt help one bit!!!!!!!!!
BTW..i just discovered the correct settings to make it smooth.....but the problem is.......the sound must be turned off 😡
