Camera delay and low video quality.
4 replies · 3,697 views · Started 21 June 2005
Hi *
I've a quite annoying problem on my 6260..
When I take a photo, 1 or 2 seconds pass before the image is saved.. Moreover, if I move the phone in these 2 seconds, the subject of the photo will not be the same anymore. :frown: :frown:
Why?
Then, the video quality is pretty poor..
Either for the resolution and fluidity.. :frown: :frown:
Any hints? :tongue:
Cheers
Dimitri
U need to get a firmware upgrade, it happend to my first phone, but doesnt happen to the new one, the only difference is the firmware 😊
what is the last firmware version?
i got the v 3.0515.0
13-04-05
RM-25
i use *#0000# and my phone show me the version, so this is the last version?
thx
for record videos use the program Camcorder 2 , the video quality is very good
for take photos dont use the normal camera use the camera in mode VGA
I had the same problem, what i found worked was that you move everything in the folder the phone saves the picture to, to another folder in your phone. Like make another folder just for pictures, so that the default folder for saving the pictures is like empty or have only a few pictures.
