Problem in setting Password
3 replies · 3,150 views · Started 21 June 2005
Hey Guys,
I am not able to set the password for a Symbian device. I am using Nokia 6600 for my testing.
Following code snippets will give you an idea of what I am doing..
// Code to take input from user, oldpassword and newpassword that needs to be set
TBuf<KAknExQueryTextBufLength> oldpassword;
CAknTextQueryDialog* dlg =
new ( ELeave ) CAknTextQueryDialog(
oldpassword, CAknQueryDialog::ENoTone );
if ( ! dlg->ExecuteLD( R_DIALOG_OLD_PASSWORD_QUERY ) )
return;
Similarly, i get the new password as well.
// Set password, and enable password checking if not enabled.
if(Password::IsEnabled())
if(Password::Set(oldpassword, newpassword ))
// print message, password set
else
// print, error message saying password not set
else
// enable password checking
Password::SetEnabled(oldPassword, ETrue);
// set password
Password::Set(oldpassword, newpassword ) ;
Even though I get messages saying password is enabled and set, but actually it does not set any password.
Moreover, when I tried to check if password that I am trying to set is valid using Password::IsValid(), it always returns false i.e password is not valid, though Password::Set() return true 😞
Please let me know if I am missing anything. Any help will be really appreciated.
Thanks a lot,
Sachin
Hello sir,
Iam working on the same task i.e password protection for the mobiles or the user authentication. I hop by now you have successfully completed the task described above which was incomplete before. Can u please help me by posting the source code. Iam a symbian beginner in developing, krishna from india.
I will be waiting for ur reply.
batistabomb
Sachin Kumar wrote:Hey Guys,
return;
else
else
// set password
Thanks a lot,
Sachin
I want the complete code for setting password protection to the mobiles. I have sent this msg many times.
batistabomb wrote:Hello sir,
batistabomb
Mr sachin Can u send me the code for setting password. i nedd it in order to use in different application. please try to help me
batistabomb
