I'v got my vodafone branded 6630 and would like to use the Go To app from time to time. Sadly i find it 'polluted' by loads of undeleteable Vodafone shortcuts which just clutter it up for me.
Any ideas on how to get rid of them or are they in ROM so its its not possible?
Cheers
B
You cant press the C button on them?
Bobagent wrote:Hi,
Any ideas on how to get rid of them or are they in ROM so its its not possible?Cheers
B
You have to get someone with an Unbranded Pinboard file to post it up and copy it over to your phone either straight over or during a backup if its protected.
Will a pinboard file from 6680 work? If yes where is it located
bjarke wrote:Will a pinboard file from 6680 work? If yes where is it located
Not sure on the compaablitiy but its located at c:\system\Data\Pinboard (no extension)
If it works post it up 😊
