Is it possible to add screensavers to my 6680. I hate the vodafone thing I have, but not sure if I can download new ones!!!!!
Can I add screensavers to my 6680??
I am interested in knowing that as well...
Just got my 6680 a day ago.
Wirelessly posted (Nokia6680/1.0 (2.04.14) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
There is screensavermaker program for pc. It gives out the .sc files which you can choose through themes menu. Quite nice app and screensavers can look much better than the default ones. Also they aren't as battery draining as the ones like wow screensavers are as they don't run through extra app.
-spimpy- wrote:Wirelessly posted (Nokia6680/1.0 (2.04.14) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)There is screensavermaker program for pc. It gives out the .sc files which you can choose through themes menu. Quite nice app and screensavers can look much better than the default ones. Also they aren't as battery draining as the ones like wow screensavers are as they don't run through extra app.
Could you post a link to this program Please.
try powerlock, it's for chnging screensaver
can someone be kind enough to post up the default screensaver inside the 6680 Z: drive ..?? is it the same as the 6630 default one..?
Doc wrote:-spimpy- wrote:Wirelessly posted (Nokia6680/1.0 (2.04.14) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)There is screensavermaker program for pc. It gives out the .sc files which you can choose through themes menu. Quite nice app and screensavers can look much better than the default ones. Also they aren't as battery draining as the ones like wow screensavers are as they don't run through extra app.
10$ on handango.com. Program name is Screensaver Maker 1.0. You also could pm me for other links. Don't know if they are allowed to post here. 😊
