Nokia 9300 or Motorola V3
3 replies · 1,959 views · Started 22 June 2005
I thinking of buying unlocked Nokia 9300 or Motorola v3. I have seen a very good price at iwirephone.com. I can't make up my mind what phone to get, any one have other suggestions? iwirephone suggested Nokia 9300.
nokia 9300 hands down.. there's no use thinking bout the V3
there's so much more you can do with the 9300, so much more memory & full keyboard...
if u want a small light phone ONLY...nothing too fancy.. then only go in for the V3
maribel wrote:I thinking of buying unlocked Nokia 9300 or Motorola v3. I have seen a very good price at iwirephone.com. I can't make up my mind what phone to get, any one have other suggestions? iwirephone suggested Nokia 9300.
Well a strange question m8 the 2 phones mentioned are from completly 2 different universes and made for difrent type for usage .
Shure u can make calls and send sms es on both but the 9300 is so much more as hyper already explained .
If u dont need or use functions that 9300 has to offer then go for v3 othervise ure choice is relly simple ...
regards laz
Indeed, a very strange question. What are you using at the moment? In my opinion you should out grow a phone 1st so until you have done everything possible with a s40 phone, go for a s60 then with all the stuff for s60 the obvious choice then is a PDA style phone or a Com. A Moto is at the moment just a phone that looks pretty. I own a V635 and even though I use it for most of my calls, it isnt my main play with phone. Hope I have helped in your decision!
lazarini wrote:Well a strange question m8 the 2 phones mentioned are from completly 2 different universes and made for difrent type for usage .
regards laz
