512k DV MMC Card
2 replies · 1,765 views · Started 22 June 2005
If you mean the ATP card, mine works fine with no noticeable loss of performance. But make sure you format it in the phone before use.
davidlove wrote:If you mean the ATP card, mine works fine with no noticeable loss of performance. But make sure you format it in the phone before use.
Sorry, it's the ATP card. My Mistake. Anyway. It arrived today. I formatted it as you suggested and it works perfectly. Slightly slower than 64K card, but mainly on copying files. With normal usage, neglible performance difference :icon14: 😊
