need help, how to play movies
2 replies · 4,653 views · Started 23 June 2005
Hi there!
I'm new to the forum, and I'm going to buy a new mobile. So here's my question:
Is it possible to play movies that I prepared on my PC? How's that work?!?
Could anyone please help me? I'm a n00b, as you can see... :frown:
Thank you all!!!
Hey, there already are some threads concerning this problem, so try using the search function next time, ok? 😊
OK, I found a new solution for movies:
There's a new codec, HDX4, and an application that can use it to convert it into mobile format. Take a look at the homepage:
www.hdx4.com
In my opinion, it's better than xvid, I've experienced several problems with it. It's up to you! 😉
cu
