System Software Versions
8 replies · 4,880 views · Started 23 June 2005
Nikyzf wrote:Thanks. So ".5.2" is in fact the important bit?
no, it's all important. just that a minor fix was done for your version.
The higher the number (all of it), the newer the firmware.
So 1.109.5.2 is newer than 1.98.5.2. However 1.109 has not been released as an update version.
stuclark wrote:The higher the number (all of it), the newer the firmware.
So "my" version is later than the one at Sendo after all? Why would it not be released as an update? Is it not from Sendo themselves?
TIA
Nikyzf wrote:So "my" version is later than the one at Sendo after all? Why would it not be released as an update? Is it not from Sendo themselves?
TIA
Yes, that is a slighly newer version, and yes, it is from Sendo.
As I said, it only has one minor fix in it, and so it was decided that there was no point doing a full set of releases just for that little fix.
plinkykev wrote:Yes, that is a slighly newer version, and yes, it is from Sendo.
Ta, even if 109 vs 98 seems like a few versions, and it's still .5.2, which brings me back to where I started, i.e their version numbering.
No need to reply to this!
Sorry, but the .5.2 does not mean it's the same version as 1.98. The versioning works in a different way.
