Hi! I'm having problems with my battery, it only lasts for a day or two! There are instances when I only make one short call and within the day the battery dies!!! I bought my p910 last may.
p910 battery life
eleobabe wrote:Hi! I'm having problems with my battery, it only lasts for a day or two! There are instances when I only make one short call and within the day the battery dies!!! I bought my p910 last may.
I think its just the phone. My battery also dies quickly, and I bought 3 batteries to cover the short life..
its not the phone! my last 4-5 days! what i did/do?
-turn blank page as screen saver (1min)
-charge ONLY when the battery level is 0%!!!!!!!!!
-turn off BT
-turn off signal setting arom Automatic to GSM (then the gprs will be switched on when needed)!!!!
-use TaskMan to switch off other apps
Something interesting I found. If you have a brand new battery, don't run it till all the juice runs out. The next time you charge that battery, in a few minutes it'll be "full", i.e. it doesn't charge properly. It happened to me twice, with two different batteries. Does anyone else experience the same thing?
