In which Steve reviews the Brando Aluminium case and fails to put a dent in it...
Darth Vader finds the perfect case for his Nokia 9500
Looks like nothing a few tins of spray paint and some masking tape won't fix 😉
I assume it needs removing to put the 9500 in a cradle?
SwitchBlade wrote:Looks like nothing a few tins of spray paint and some masking tape won't fix 😉I assume it needs removing to put the 9500 in a cradle?
Don't buy this if you use a cradle. Personally, I just leave Bluetooth on and the 9500 auto-connects to PC Suite whenever I'm in the same room 8-)
Steve
Another q is it as big as the 9210 in that case or larger?
SwitchBlade wrote:Another q is it as big as the 9210 in that case or larger?
Larger, mainly in terms of thickness.
Steve
