Formatting the X800
2 replies · 4,207 views · Started 25 June 2005
Would like to know what codes do I enter to format the Panasonic X800?
I know *#7370# works on the 7650, but it doesn't on the X800.
Thanks.
No, but the X700 reformats with **7370# (note the two asterisks instead of *#) and I suppose the X800 will do, too (as it is basically the same phone with a different look & feel).
N/A wrote:No, but the X700 reformats with **7370# (note the two asterisks instead of *#) and I suppose the X800 will do, too (as it is basically the same phone with a different look & feel).
remember to do a back up otherwise you`ll lose it all
