sorry this question is some how repeated but...
what's the different between *#7370# and *#7780# ??
and in this statement:
" 3. When you see the NOKIA Welcome screen, immediately press and hold down the [= (Left Key) +Menu [.-
The Key [.- should be press at last."
what is "[= (Left Key)" and "[.-" ??
I can't format using this method
The first two just remove user data/settings and the last option completly formats the c: drive. It then reloads the required files the device needs to run from the ROM.
If you do not have any info you want to keep on the device, use the second option.
badger wrote:The first two just remove user data/settings and the last option completly formats the c: drive. It then reloads the required files the device needs to run from the ROM.If you do not have any info you want to keep on the device, use the second option.
Thanks for reply
for the last one, I keep pressing the two keys but nothing happend ,have you test it?
