can one add a wireless card to the 9300
7 replies · 2,613 views · Started 26 June 2005
Hi there
I am thinking of buying a 9300, but wondered if one could add a wifi card for those few times when one needs it
thanks
leon
badger wrote:NO,
The 9300 uses MMC cards and what you are proposing is only available using SDIO cards.
What about attaching Wi-Fi USB dongle to the pop-port?
No to that, too. There is no such Wi-Fi dongle you could attach (and you'd need suitable software for the phone, too).
if u were to add something at the pop port, then you would make the phone bigger in size.... y not just buy a nokia 9500...
HyPeR wrote:if u were to add something at the pop port, then you would make the phone bigger in size.... y not just buy a nokia 9500...
That's the thing. What if I do not want to carry around extra weight for Wi-Fi enclosed in 9500 all the time? What if I only might need Wi-Fi on occasions?
And what if my Wi-Fi network is 801.11a (or g)? Wouldn't it be nice to have add on type of dongle? I think it would not be a big problem to fit USB dongle to the Nokia Pop-port. Software could be a bigger problem. Does anybody know any 3rd party software to control Wi-Fi on Symbian OS?
N242 wrote:That's the thing. What if I do not want to carry around extra weight for Wi-Fi enclosed in 9500 all the time? What if I only might need Wi-Fi on occasions?
leonh wrote:
thanks gentleman,
there is nothing that does everything is there, just when i think I have found the machine I think of another thing that i want
leon
