I am using 7610. Can't find a way to set a recurring alarm. Any idea of doing this or any free 3rd party software can do this? tq
How to set recurring alarm clock
i couldn't find the recurring alarm in the alarm menu. but i can suggest a poor workaround if that helps :
use calendar - define a daily meeting with an alarm setting ..
ajaychandna wrote:i couldn't find the recurring alarm in the alarm menu. but i can suggest a poor workaround if that helps :
This kind of schedule will not alert when the hp is power off. BUt alarm clock can. Any 1 have 3rd party freeware to suggest for the recuring alarm clock setting pls.. tq
HandyReminder
My uncle is an importer of goods and has to travel frequently. As he is on different time zones, it is necessary for him to be on time for appointments. Is there an alarm clock that is functional, effective and compact?
Hi ReyesBurns,With all modes of transport being crowded to day, it is important that one should have an alarm clock that wakes one up with a gentle and silent vibration without disturbing the rest of the people who are traveling with you. It is the best travel companion for all short and long-haul trips for businessmen and frequent travelers. It is compact enough to be kept it under the pillow or in the pocket.
