9500 Corrupted Outer Screen
1 replies · 1,848 views · Started 27 June 2005
I've been having a few problems with my 9500,
The outer screen starts getting corrupted, 😞
Sometimes pressing the power button restores this back to normal,
Or opening the communicator,
But other times the screen appears to flicker like old interlaced PC screens used to and then the only way to get it back to normal is a reboot (Battery out),
I noticed this since I installed SClocks from Symbianware,
Any idea's whats gone wrong? How do I fix it?
Carl,
First step would be to remove the software, see if it is actually that making the difference.
Other than that, it could be a faulty screen, but before shipping it back anywhere to get it replaced, try a hard reset on the device and see if the problem continues
