You know, to get at all those little bits out from between the keys, or under them?
What do you use to clean your keyboard?
lakeywhite wrote:You know, to get at all those little bits out from between the keys, or under them?
Do you mean on the 9500? Nothing is stuck between my keys...However, if you mean computer keyboard, I believe a toothbrush works well or pipe cleaner.
Yes on the 9500,
I use mine outside a lot, when I am out enjoying the countryside I write things down. I seem to have pickedup dust and dirt particles, I normally get them befor they go under the keys but some have managed to get through.
why not try compressed air
I use a soft brush and Isopropyl Alcohol (Medical grade),
Kills all the germs, cleans the screen a treat too,
Carl,
Ok people, thanks.
I was sorted with cleaning the surfaces with isopropyl, I just needed to get between and under so I will try the compressed air route.
