Hi guys,
is there a program or anything that can be done to increase nokia 3650 ringing/louspeaker volume?
2, what program can be used to convert cd music with extension cda to mp3 or avi.
Thanks for the assistance.
Hi guys,
Ringing volume depends of volume of ringtone + speaker s enough weak. To increase its loudness is impossible, its possible to increase only loudness of loaded ringtones/sounds. cd 2 mp3 - theres too many of soft. 4 example, Advanced CD Ripper Pro, JetAudio, etc.. but not in avi, this is video format
Niobeast wrote:Ringing volume depends of volume of ringtone + speaker s enough weak. To increase its loudness is impossible, its possible to increase only loudness of loaded ringtones/sounds. cd 2 mp3 - theres too many of soft. 4 example, Advanced CD Ripper Pro, JetAudio, etc.. but not in avi, this is video format
Hi Niobest,
Thanks for the reply, when you say increasing the volume of loaded ringtones/sounds, how do you go about doing that when you have already increased the volume of the phone to the highest and its not audible enough.
bodexus wrote:Hi Niobest,
There is nothing u can do with it!!!
Nothing besides buying some newer phone with louder speakerphone, something like 6630
Cheers,
Apoc
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
I find that the primitive .RNG files are the loudest.
To bad they sound like 😛uke: (monophonic)
here is one i converted from midi : Airwolf
bk227865 wrote:I find that the primitive .RNG files are the loudest.
To bad they sound like 😛uke: (monophonic)here is one i converted from midi : Airwolf
and with what soft possible to convert wav/mp3/wma in rng?
