Cheapest place online for 512MB DV RS-MMC?
7 replies · 3,913 views · Started 28 June 2005
Hello
Does anyone know the cheapest place for a Dual-voltage Reduced size MMC for my Nokia 6680?
The cheapest I've found is here for �40. Just wondering if anyone knows of a cheaper one?
be careful as I believe those RS-MMCs are not dual-voltage... if you look at the detailed specifications they show that they need at least 2.7V to operate.
Utenteanonimo64 wrote:be careful as I believe those RS-MMCs are not dual-voltage... if you look at the detailed specifications they show that they need at least 2.7V to operate.
But here is the spec
Complies with the MultimediaCard Association standard specifications, version 2.11
Non-volatile solid-state, therefore the data is not lost when the power is turned off
Read Speed of 1.7 to 2.5 Mbyte/sec and Write Speed of 0.4 to 2.5 Mbyte/sec
18mm Wide x 24mm Long x 1.4mm Depth
Only weighs 1 gram
Low Power Consumption
Voltage :- 2.7V to 3.6V
Dual Voltage :- 1.8v and 3.0v
5 Year Warranty
When used with the included adaptor the Mini MMC card is compatible with a wide range of devices that feature a full sized MultiMediaCard slot
Is that not right then?
