3660-Cannot Boot After Installing .gdr files!!I don't really understand prev topic...
2 replies · 2,560 views · Started 28 June 2005
Can anyone give me an advice or solution???
After I uninstall a font then I made a fonts directory in C:/system
then I restart my phone...Then it appears only "NOKIA" and it on and off about 3 or 4 times .... every time I try to swith it on...
PLZ HELPPP T-T...I think somebody must write a note about not to install that gdr files on 3650/3660 hehehe (just joking no offense ^^)
sorry for my bad english...
It can be very difficult because OS6 phones doesn�t support three key boot up trick.
I�m afraid that phone reflashing is only solution right now�
Cheers,
Apoc
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
Apocalypso wrote:It can be very difficult because OS6 phones doesn�t support three key boot up trick.
Cheers,
Apoc
yess indeed...and i have my phone flashed already T-T..luckily before I change the font I back up the phone memory first [the instruction told me to do it =)]...it quite expensive for an idiot error like what I did....Not Worth it (75.000 Rupiahs = around 7 USD).....hMm so you're saying that if this happens in 7610 it would be easy to re format it??with 3 key boot method??
hMm so is it save to install the .gdr fonts???or .sis ??? anyone????any advice / recommendation??
before I changed it to .gdr I changed the default font to Tahoma.sis first....then it works without error....
thx ^^ for your reply....
sorry for muh bad english...i'm sure there is a lot of grammar mistakes above...-.-""""
