[Help] How to Backup/Restore SMS to/from RS-MMC?
6 replies · 3,846 views · Started 29 June 2005
Anyone knows how to backup SMS only from Nokia 6260 to RS-MMC without using any 3rd party software? If it's not feasible, then suggest a good 3rd party software. I'm getting my Nokia 6260 flashed with the latest firmware soon and I need to backup and restore all my SMS. Thanks 😃
DaViD_BRaNDoN wrote:Anyone knows how to backup SMS only from Nokia 6260 to RS-MMC without using any 3rd party software? If it's not feasible, then suggest a good 3rd party software. I'm getting my Nokia 6260 flashed with the latest firmware soon and I need to backup and restore all my SMS. Thanks 😃
you can also use backup function on nokia pc suite.Just make backup of your sms file.After falshing,simply upload it back to the fone, 😊
Thanks for the heads up. Anyway, more questions...
- Anyone ever use the built-in 'backup' feature on Nokia 6260 (Memory > Options > Backup phone mem.)? Does it backup/restore SMS?
- Say I'd backuped my SMS using Nokia PC Suite's backup feature. Can I restore those SMS to another phone (either same or different model)?
