I own about 15 ngage qd games. I also own a 256mb black mmc card. I dont want to walk around with a bunch of mmc's in my pocket. Is there ANY way i can put all the games onto my 1 mmc 256 mb so i dont have to carry aroudn ALL THESE CARDS! Plus I noticed that the ngage only has 1 spot in the menu for a game so i dont know if my idea can be done.
Can you answer this question
I think you can do:
1. make sure there is a directory of E:\system\apps on your MMC card;
2. copy the directorys system\apps\<gamename> from each your game card into the same place on your 256M MMC card
3. restart your N-gage, then you can play all games in one card
If you copy the actual N-Gage game card files to another MMC, they won't work/run from the other card.
Other, installable apps can often/usually be copied that way.
