Help, got a se p910i but i cant get in to file manager 😡 can back up and restore and install programs but cant put across mp3 etc . have done a format disk and it comes up saying your disk is corrupt but still cant get the file manager to work any ideas??????? as it will only a short time before it goes in the bin
File Manager
if you want to swap it for a pristine P800 fully functioning, pm me 😉
anyway, if you can back up and restore (via PC suite right? you'll have a phone icon in your systray), your windows explorer should have an icon which is your phone. Double click on it, and you'll see the C and D drives (if you have a mem stick installed). You will only be able to see the media files folders, which should be enough for what you want to do.
If you want to see all folders on your phone from your PC, look at EpocWare's (or Symbianware's) PC file manager / desktop file manager
However, the write speed to the phone is painfully slow, so if I was you I'd get a cheap card reader and stick it into your USB port, and your file transfer will be done in seconds.
