I have installed picodrive on my 7710 and 26 games which i have put into a folder called PDGames as directed.
When i launch picodrive i get a screen which says 'load rom' but when this is pressed nothing happens.
How do i get picodrive to find the roms ??
Anyone got picodrive and games working on 7710 ?
what version of picodrive did you install ??
try the last version 0.4 (support zip files)
if you have version 0.2 you have to unzip the files
and put it's in the PDGames
tip:
if you use the ver 0.4 (support zip files)
unzip the files too, it's speed the loading time
Thanks blueredman,
Stupid me, forgot to unzip the files, no wonder they would not work !!!
Got them working now but the version of picodrive is 02 so i will have to try and find the newer version, no sound though, is this normal ?
Just got to sort out the tom tom 5 now, still not got it running.
Now, whats next !!
😉 , you have the old version( no sound )
the new version support sound (partial sound) because there
is no Z80 emulation
try the link
http://picodrive.atspace.com
give to Neil Davis the credit :icon14:
tip:
what is the start button for 7710 in settings i can only modify a b and c button
freewill wrote:what is the start button for 7710 in settings i can only modify a b and c button
The start button is the green button on top to answer a call, it also took me a long time to find it out hehhe
thanks a lot 😊
how can i get game for pico drive? pls help me . i cant use it 😞
thanks
bye
