Hi all..
When I am making a new project using the Series 60 AppWizard, I have 4 cpp files(and offcourse the header class description files ). As an Example
CSearchapp.cpp
CSearchui.cpp
CSearchcontainer.cpp
CSearchDocument.cpp
But as I saw some Examples in the SDK Documentation(Like BTDiscovery)
there is a class called XXview.cpp. My question is, is this view class necessary to work in the Epoc Framework?Or it is a developer'S choice?
It is really not very clear to me which classes and objects I should be working with (Like view class or Ui class)........can someone post a short tutorial that explains what which classes are doing and what kind of classes should be used for working in which kind of Methods and functions.
Like, if I want to add a function, which class I should add that function and how I will undersatnd that....an Overview on the EPOC Framework.
Thanx.... 😊
