Logfile
3 replies · 1,917 views · Started 07 November 2002
Hello,
Does anybody knows how to open the logfile in OPL? I want to open the logfile and read the lines 1 by 1 from it (to do some calculations).
I try to open the file c:\system\data\logdbu.dat, but i get the message: File is in use, even when all apps are closed.
Help!
Greetings,
Jack
It's not a file you can IOOPEN or OPEN, it's not an OPL format file or a plain text file. The only way to access it is to write yourself an OPX which uses the supported Log access classes to read from/write to the log.
Regards,
Phil
Thanks for the answer. Can you (or anybody else) tell me if that's also possible with Mobile VB?
Regards,
Jack
because the file is in use no program can read it. (the ones who can are the ones using it 😉 or they kill that what's using the file)
