Camera Shutter sound
7 replies · 6,556 views · Started 04 July 2005
mht220 wrote:Is there any way to turn off the shutter sound of camera in 7710 like in 6630?
i posted this question ages ago and got no replys so i don't think you can turn it off i've got photobase and u can't turn it off on that aswell which is naff
spidernet21 wrote:Have you tried putting the device in silent mode and then taking a picture?!
yes, but no different
I've found two ways to get rid of the shutter sound. Perhaps the easier one is to just attach the headphones, though it doesn't actually remove the sound, it will make it play through the headphones instead of the loudspeaker. Other way is to put the audio player playing something muted while taking the picture. It's not enough to just set the players volume to muted, it has to be playing something too.
Zerion wrote:I've found two ways to get rid of the shutter sound. Perhaps the easier one is to just attach the headphones, though it doesn't actually remove the sound, it will make it play through the headphones instead of the loudspeaker. Other way is to put the audio player playing something muted while taking the picture. It's not enough to just set the players volume to muted, it has to be playing something too.
thanx the second way is great
