Hi all,
I have a nokia 6680, and I am trying to add some goodies onto my phone, I have no trouble sending it via bluetooth, but when i open it I recieve an error tone and the words " Installation security error unble to install"
This is on every .sis file I try.
Any ideas anyone??
Im am on vodafone.
Many thanks
Bod
Hi mate.
Sounds like you need to enable software installation, goto your "manager" then options/settings/software installation and set it to 'on'
Best of luck, it's a great phone hope you enjoy using it as much as I do mine 😊
Will
willbrady wrote:Hi mate.
Sounds like you need to enable software installation, goto your "manager" then options/settings/software installation and set it to 'on'Best of luck, it's a great phone hope you enjoy using it as much as I do mine 😊
Will
Thanks Will, I was having the same problem 😉
Nice one will worked a treat.
Dont suppose you know how to get the smart movie going on a 6680?
Can install it, but open it and nothing happens, have heard there are other people in the same boat?
V2.73 works without any problems on my 6680 (installed on the memory card).
