I cannot find the download section in smartphones.com
Do I need to have a log in?
I believe it is under the software section.
Rafe
Rafe wrote:I believe it is under the software section.Rafe
Can someone post the REAL link to the section?
I've decided to move it to the top level of the Main Menu, as some of you can't see it 😉
You don't need a login to see the downloads.
stuclark wrote:I've decided to move it to the top level of the Main Menu, as some of you can't see it 😉You don't need a login to see the downloads.
Finally found it, I guess it resides in a submenu tree. Maybe a color change would help notice this tree.
