😡 Hi group nice to know there is a palce to post our probs regd 6260..
My problem is when ever i try to open some application, it just wont work. But the icon is present in the desktop and it is installed successfully. Can anyone help me plzzz.
smn
smn
It might help, if you stated what "wont work" means. What happens when you try to launch the app? What application is it, exactly (name & version, minimally)? Did you install it yourself? Was it installed from a .sis or .jar file? How did you copy it to your phone? Does it help if you remove and reinstall it? Any installation errors you may have missed?
If the apps are not legal versions, then buy one and ask the developer for support. (And expect no help with illegal apps on these forums; http://www.allaboutsymbian.com/forum/faq.php?faq=faq_rules#faq_rules).
N/A wrote:It might help, if you stated what "wont work" means. What happens when you try to launch the app? What application is it, exactly (name & version, minimally)? Did you install it yourself? Was it installed from a .sis or .jar file? How did you copy it to your phone? Does it help if you remove and reinstall it? Any installation errors you may have missed?If the apps are not legal versions, then buy one and ask the developer for support. (And expect no help with illegal apps on these forums; http://www.allaboutsymbian.com/forum/faq.php?faq=faq_rules#faq_rules).
Dear N/A
Thanyou very much for your info, actually, I had installed these applications from .sis only, and these applications were working fine, but now when i press the icons it does not do anything, I have the sis files with me so i deleted and reinstalled, but still the same thing happens.. applications like fscaller, Blacklist, disco, answeringMachine and so on...
Hope you can undersand my problem now...
Regards SMN.
smn wrote:Dear N/AThanyou very much for your info, actually, I had installed these applications from .sis only, and these applications were working fine, but now when i press the icons it does not do anything, I have the sis files with me so i deleted and reinstalled, but still the same thing happens.. applications like fscaller, Blacklist, disco, answeringMachine and so on...
Regards SMN.
By any chance do u have illegal/cracked versions?
