--How to send Java games to 6260?-
2 replies · 2,198 views · Started 06 July 2005
Hey could anybody tell me how to send java games trough bluetooth to my nokia 6260? is it possible trough bluetooth? :frown:
Send them from where? If from your PC, then yes; most Bluetooth software (at least on Windows) installs a Bluetooth piece in the "Send to" menu that you get when you right-click on a file (in this case the .jar file you want to install) in Windows Explorer.
N/A wrote:Send them from where? If from your PC, then yes; most Bluetooth software (at least on Windows) installs a Bluetooth piece in the "Send to" menu that you get when you right-click on a file (in this case the .jar file you want to install) in Windows Explorer.
thanks 4 your reply,
yes from PC to the nokia trough bluetooth, will tehre be any problems?
because the Samsung E720 its nearly impossible to send .jar/.jad files :frown:
