Hi there.
Today i finally got my new cell. It's a wonderful 6680.
I have some small question for you experienced tweakers:
1) Is there a way to lock phone? i mean a five digits keycode i should entry at any time for locking my cell; a keycode i should entry every time i tuen on my device
2) can anyone please suggest if it's possible to use more visible fonts? they look too small for my old eyes...
3) where to find additional themes? Maybe for free? 😊
Thanks in advance for helping
lsangio
free themes, a great site!!!!
http://www.phoneyworld.com/downloads/nokia_6600_themes/index.aspx
one of the best! then we have
www.zedge.no (free yes, but you can only' download 15 themes a day!)
1) menu > Tools > Settings > Security > Phone and SIM
- PIN code request: On
- Autolock period: User defined...
- Lock code: [default is 12345; change to something else and *DO NOT* forget what it is]
- Lock if SIM changed: Yes
3) http://www.symbianthemes.com
thanks a lot for helping.
Now, what about some fonts tweaking? mines look so smaaaaalllllllllllllll................
cheers
Luigi 😉
lsangio wrote:thanks a lot for helping.
Now, what about some fonts tweaking? mines look so smaaaaalllllllllllllll................cheers
Luigi 😉
do you mean your font is 'thin'? if its thin you have the chinese version of the unit, you cant possibly tweak the fonts. what you have to do is have your phone's firmware flashed at any nokia center (free if under warranty)
for original nokia themes (signed, except theme5) go to:
http://www.nokia.com/nokia/0,,71438,00.html
thank you.
What i mean it that i can hardly see my SMS's text when writing.
I have installed and executed Font Remover and installed Tahoma.sis.
All is OK except those :icon13: small fonts in SMS's text....
Can you help?
Thanks again for patience
lsangio 😉
lsangio wrote:thank you.
All is OK except those :icon13: small fonts in SMS's text....Can you help?
lsangio 😉
i never liked those font removers, it causes problems, have you tried to reset your phone to its factory settings? this might solve the font problem, but mind you it 'may' erase a lot of data, BACK UP and try to do reset or hard reset. for resetting read the manual or for hard reset *#7370# (again this will delete all data on your phone)
tsupatsupa wrote:have you tried to reset your phone to its factory settings? this might solve the font problem, but mind you it 'may' erase a lot of data
i'm a bit afraid of it...
if i simply could install a larger font for SMS's text.....
thanks for helping
lsangio 😉
Install FExplorer (www.gosymbian.com) Navigate to C:\System and delete the "Fonts" folder. Restart your phone, then the original fonts are back.
bjarke wrote:Install FExplorer (www.gosymbian.com) Navigate to C:\System and delete the "Fonts" folder. Restart your phone, then the original fonts are back.
if u have installed the new fonts, u can't deleted it like that as it will stated font in used, u need font remover to do that.
i didn't like default fonts so i installed TAHOMA.SIS; i like this font but SMS's fonts are so small! I uninstalled via font remover TAHOMA font and now default SMS's fonts are there, a little readable but not so neat.
any help?
thank you all for suggestions
lsangio
