ATTENTION! This theme is ONLY for the firmware version 78 (1.198.8.2)
:icon4: modified version
Amazing, tnanks 😊
Thanks will take a look at it 😊 Can you also post the pkg and source files? Would be cool for a help for me to create new themes 😊 Thanks.
murphy
All the icons are messed up in my main menu.
IF I can get enough network coverage, I'll post a screenshot in a minute.
stuclark wrote:All the icons are messed up in my main menu.
noticed that too:
Thanks 😊
With the terrorist attacks in London this morning, I can't get a signal to transfer the picture from my phone to the internet.
Really strange! I have only modified the animation and the themeicons. And in my phone the menu is correct! I've the italian version, I think that the problem is in the appicons file (in the rom). I'll try to make an alternative version...
Ok, I've added the appicons file in the theme. I hope that this will fix the problem.
ermete3smegisto wrote:Ok, I've added the appicons file in the theme. I hope that this will fix the problem.
I used the old one and it works here without problems. France Firmware, uses English as default language.
There are differences in some of the default icons between the Expansys and French firmwares - maybe this is something to do with it.
Ermete once again, you the man! :icon14: 😃
stuclark wrote:There are differences in some of the default icons between the Expansys and French firmwares - maybe this is something to do with it.
Thanks once again ermete3smegisto - that's excellent. :icon14: I have the only theme I need on my Sendo now!
And that's a great idea, Murphy, to make a theme editor. Presumably if you know where to put each part you can automate the process and help us who are more technically challenged.
mart1138 wrote:Thanks once again ermete3smegisto - that's excellent. :icon14: I have the only theme I need on my Sendo now!And that's a great idea, Murphy, to make a theme editor. Presumably if you know where to put each part you can automate the process and help us who are more technically challenged.
That's a good idea. If somebody could post a step by step guide on how to create a theme, i could maybe try to create a small application that would automate the process if i can find some time to do it.
Im currently investigating the default theme. It seems that it all has in it that is customizable. I will try to create a small theme editor with a preview. I hope this goes well next weeks...
Looking forward in new future for Sendo X
Cheers, murphy
A "new" Theme which I created several weeks ago for the new firmware, based on Silver Lime.
the blu bip caused my X to crash...the only one that seems to be stable is Silver Lime...yes I have the latest firmware
