I have Nokia 6600, I install any application on my MMC after that this error fired,
I Off phone and then on it but error popup apper.
Then i format with #*7370# and restart but error apper.
Then i format phone with {Green button +3+*} after that error popup still apper,
Help me to format my MMC
System Error [App.Closed AppArcServerThread]
you can try formatting your MMC using a card writer/reader.
hope this helps.
Any other Solution?
Ito pa isang paraan Mga kailangan: AutoEXEC at MCFixer and Charger hehe Mga dapat gawin: 1. Wag muna einsert ang mmc sa phone. 2. Einstall ang dalawang Apps sa phone memory. 3. Open AutoEXEC click options-add entry-add application tapos hanapin mo yun MCFixer click ok. Click options ulet-edit entry-click ok on the File name then select MCFIXER.APP click ok and turn off your phone w/out exiting AutoEXEC. 4. Insert now your Mmc in your phone. 5. Charge your phone, an application will pop up thats the MCFixer now if the "App. Closed AppArcServerThread" still flashing just ignore or click ok. Click nyo lang sya ng click hanggang maclick nyo options ng MCFixer then click Format drive. Ayun tapos na!
