this is to know if it's possible to turn off the sounds when we turn on or turn off the phone differently that put the "mute" mode.
can we give a ringstone for each contact? that's to say, when a different contact call us, there is a different ringstone for each of them.
sendo94 wrote:this is to know if it's possible to turn off the sounds when we turn on or turn off the phone differently that put the "mute" mode.
It's possible if yuo create a custom theme (if you have the latest firmware installed refer to this thread
http://www.allaboutsymbian.com/forum//forum/thread/38963/)
sendo94 wrote:can we give a ringstone for each contact? that's to say, when a different contact call us, there is a different ringstone for each of them.
The only way I know to doi this is to create a group under your phonebook and then assign the desidered tone to it. (a group can be composed of only one entry in your phonebook)
thank you
but the link to mbmwizard doesn't work......
and do you know if a kingstond SD works on the sendo X (espescially the elite pro)
sendo94 wrote:but the link to mbmwizard doesn't work......
Try with this link (and in general take a tour on symbian freak site, very interesting):
I think that any SD should work with the X, maybe not at full speed. I'm using a Kingston 512MB (not the elite, too expensive 😉 )
I think that any SD should work with the X, maybe not at full speed. I'm using a Kingston 512MB (not the elite, too expensive 😉 )[/QUOTE]
what do you mean by :" not at full speed"?
and has anyone dust on the screen?
I have a lot on mine....is it possible to remove it?
sendo94 wrote:what do you mean by :" not at full speed"?
I mean that the read/write speed of the SD could be higher than what the sendo x cand handle (but I don't know these parameter).
sendo94 wrote:and has anyone dust on the screen?
Someone had this problem, refer to this thread to learn how to disassemble the housing:
http://www.allaboutsymbian.com/forum//forum/thread/33912/
