Orange UK have added a couple of apps that i don't want (excluding the crap homescreen). i have deleted one app but the fireplayer app i wouldn't mind keeping, but i want it on a mmc and not in the phones memory. i have the option to move or move to folder, but i cannot work out how to move it to the mmc? any ideas?
cheers
Rich
moving a pre-installed app to the mmc?
If the app is installed in phone memory (C-drive), you could try moving every file related to the app with FExplorer (http://www.gosymbian.com).
If the app is installed in ROM (Z-drive), it can't be moved with any means (on the other hand, it is then not consuming any memory you could use for other purposes anyway).
cheers
I've found the file is copyright protected so after i found it using FExplorer i couldn't do any thing with it.
I've also found the app is avalible to download anyway from the orange wap site
