Has anyone got tom tom 5 with uk maps for the 7710 yet ?
It is out but seems very hard to find as 99.9% of the ones available are for the symbian 60 phones ( 6600 etc )
I have 4.43 running but every time i exit the program then restart it the language changes to italian even though i set it to english, does anyone know which file to change/delete to stop this.
I also need a gps fix for this as it is currently set to use the original tom tom gps receiver.
Any help appreciated
Hello no v5 not but with the Prob Language after Restart i can help U
U have to delete the File Game.CFG in System/Aps/TomTom
2 Could you Send me 4.43 all versions i found does not Work
[email][email protected][/email]
ThX in advance
iang27 wrote:Has anyone got tom tom 5 with uk maps for the 7710 yet ?It is out but seems very hard to find as 99.9% of the ones available are for the symbian 60 phones ( 6600 etc )
Could you send me also that version? I can't find anything to. [email][email protected][/email]
I now have tom tom 5 running on my 7710 but i cannot get the tom tom program to see my gps receiver even though tom tom 5 is meant to work with any receiver.
In the gps menu there is only one choice for the gps receiver which is the genuine tom tom receiver, does anyone know which file it is that contains the gps files so i can add one from another version of tom tom to enable any gps receiver to work.
