Can't find the System Folder
11 replies · 3,810 views · Started 09 July 2005
Hey,
I've bought yesterday a Nokia 6630.
I've already download lots of games and apps..
By a Game most i come into the System folder.
I've put my MMC into the MMC Drive of my PC and i see no System folder.
With my Nokia 3650 I have many times come into the System folder (#:/System)
But since i have bought a Nokia 6630 AND installed Nokia PC Suite 6.? I can't see it any more.
I've click in a folder on Extra>Folder Propties And change some things.
But it didn't work.. 😡 :frown:
Maybe you know what to do about it..
I'll hope so.. 🙄
Greetz Sandrino
P.s. I come from Holland sow i can type english very wel.
In dutch :tongue: : Ican't speak english very well, Maar nog niet zo snel.. Maar dat komt nog wel :P
Sannysite wrote:Hey,
I'll hope so.. 🙄
Greetz Sandrino
Have you enabled the view all files option on your PC as that hides things like system folders even on external devices like memory cards.
Sannysite wrote:I don't now...
Where can I find that option?
On XP Pro its here...
Start
My computer
Tools
Folder Options
View - tab
Advanced Options - window
Show Hidden Files and folders
Go to MY COMPUTER
Go on to TOOLS ->Folder Option -> View -> Show Hidden Files and Folders
And then Ok
Yes I've done that before..
But it don't work..
But other files that are hidden can I see..
😡 What's happing? :frown:
Sannysite wrote:Yes I've done that before..
But it don't work..
are you sure the folders actually exist - have you got anything important on the card. try formatting it on the phone.
After ya selected "show hidden folders" ya then got to do a search of card. This will show up everything as a list.
Faded folders are the hidden ones.
Right click on faded system folder and go to properties.
Unclick "hidden"
you will now be able to see the system folder in normal windows.
Hidden folders are usually just "System" and "PAlbTN"
Have ya installed FExplorer on phone?
Ya can then see if folder exists while card still in phone
I've done things again..
Back-up some files from my MMC and format it..
I put the MMC into the drive and again NO system folder..
This is very whird isn't?
Can anybody make a Print-Screen of his ;
Tools>Folder Propeties> View
?? Maybe is that a Help.. :frown:
I hope you that for my 🙄
Very much greetz,
Sandrino From Holland
I forget to say something.. 😊
I've installed FExplorer.. And yes i see System on my Mobile.
But NOT on my PC.. :frown:
Gr. Sandrino
PC Suite and its Phone Explorer does not show the system directory.
I have no trouble seeing it on my memory cards through a card-reader, though.
Sannysite wrote:I've done things again..
Very much greetz,
