9500 Flip Problems
2 replies · 1,918 views · Started 10 July 2005
My 9500 flip is not fitted in proper way, on the right side there is slight space(1-2mm more than the left side) when i close my 9500 flip and if i pressed it, i can feel it bounce.
and after 2 month usage i can feel that the flip is getting easier to open and it always accidentally opened. and it is really2 disturbing.
Does anybody experienced the same problem with their 9500?
I do not recognize the problems that you describe on my own 9500. I think yours is faulty, so you should go to your dealer asap and demand to get it fixed under warranty. Sounds like a flaw in the assembly.
;( too bad..my dealer is in indonesia and i'm in states right now, i bought the phone just a few days before i depart to states -_-" anyway..thx for the advice ^^
