Smart movie
9 replies · 5,165 views · Started 11 July 2005
Wirelessly posted (Nokia 7610: Nokia7610/2.0 (4.0437.4) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Hi all. I installed this application in my 7610. It installed properly. But when i tried to open it, it didn't. I tried to open an avi file with it, but still it didnot open. I have seen my friends using that in their 6600s. But never seen anyone using it with 7610. Is it compatible with 7610s? Pls help!! Thanks in advance.
N/A wrote:I've used SmartMovie with a 7610 (nowadays on a 6680). What version did you try? Latest version on http://www.lonelycatgames.com/ is 2.73.
Any wap website i can down
Alsay wrote:Wirelessly posted (Nokia 7610: Nokia7610/2.0 (4.0437.4) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
I have installed the 2.73 version. Still the same happens
smart movie player works on 7610 but if u have an registered version u can play files the software which comes with this player helps to convert mpeg files to smart movie player files and u can use it iam also using smart player on 7610
I have three versions of smart movie. Even 2.73. When i install it in any other compatible mobile.., it works, and when i try the same with my 7610, it doesn't work.. This is frustrating..
It is working now. It was my MMCs problem. When i format it, every thing became ok. Thanks for the contribution
parag_b wrote:smart movie player works on 7610 but if u have an registered version u can play files the software which comes with this player helps to convert mpeg files to smart movie player files and u can use it iam also using smart player on 7610
Can you tell me the license key for the smartmovie 2.76?
